Maximize your work space with this innovative monitor riser and stand, shaped to fit into the corner of a cubicle or corner workstation. You can raise your computer screen by placing it on this platform, for a more comfortable viewing, while saving desk space.
Set this sturdy height-adjustable monitor stand into the corner of your workstation, to support a monitor up to 32" in size and up to 33 lb. (15 kg) in weight. It sits neatly on your desk or table, leaving space for storage underneath. The monitor shelf even has a drawer to hold office supplies.
Create a workstation that works best for your needs. This monitor riser features legs extenders, giving you a choice of two heights for your monitor stand: 2.8" or 3.9" (7 cm or? 1? 0 cm).
The corner monitor stand makes it easy to create a clutter-free workspace. In the area under the desktop stand, between the legs, there is space to place a small laptop. A convenient drawer gives you a place to keep pens and other small office supplies.
The PC monitor stand is easy to assemble. The rubber feet on the bottom of the legs protect your work surface from scratches and ensures your monitor rests securely while you work.
Product Description | StarTech.com Monitor Riser Stand for Corner Workstation - Height Adjustable - stand | Product Type | Stand | Dimensions (WxDxH) | 27.1 cm x 55 cm | Adjustable Height | 7-10 cm | Adjustments | Height | Weight | 2 kg | Recommended Use | Monitor | Recommended Display Size | 32" | Max Load Weight | 15 kg | Material | Plastic, MDF | Colour | Black | Package Content | 4 x rubber feet, 4 x stand risers, 4 x riser extenders | Manufacturer Warranty | 5-year warranty |
General | |
Width | 27.1 cm |
Depth | 55 cm |
Weight | 2 kg |
Colour | Black |
AV Furniture | |
Type | Stand |
Drawers Qty | 1 |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 27.8 cm x 55.5 cm x 6.3 cm / 2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
