StarTech.com Monitor Riser Stand for Corner Workstation - Hei...
StarTech.com Monitor Riser Stand for Corner Workstation - Height Adjust
£29.26
Delivery:
Standard: 1-3 working days
Key features
  • Height-adjustable monitor stand, shaped to fit into corner workstations, sits easily on your desk, 21.7” x 10.7” x 3.9” (55 x 27 x 10 cm)
  • Raises a monitor for more comfortable viewing ?(max weight: 33 lb./15 kg, max size: 32")
  • Leg extenders let you choose between two different heights: 2.8" or 3.9" (7 cm or ?1?0 cm)
  • Stock Status: In Stock
Product codes
Maximize your work space with this innovative monitor riser and stand, shaped to fit into the corner of a cubicle or corner workstation. You can raise your computer screen by placing it on this platform, for a more comfortable viewing, while saving desk space.
Set this sturdy height-adjustable monitor stand into the corner of your workstation, to support a monitor up to 32" in size and up to 33 lb. (15 kg) in weight. It sits neatly on your desk or table, leaving space for storage underneath. The monitor shelf even has a drawer to hold office supplies.
Create a workstation that works best for your needs. This monitor riser features legs extenders, giving you a choice of two heights for your monitor stand: 2.8" or 3.9" (7 cm or? 1? 0 cm).
The corner monitor stand makes it easy to create a clutter-free workspace. In the area under the desktop stand, between the legs, there is space to place a small laptop. A convenient drawer gives you a place to keep pens and other small office supplies.
The PC monitor stand is easy to assemble. The rubber feet on the bottom of the legs protect your work surface from scratches and ensures your monitor rests securely while you work.
Product Description StarTech.com Monitor Riser Stand for Corner Workstation - For up to 32" Monitors - Height Adjustable - Corner Monitor Stand (MONSTNDCORNR) - stand
Product Type Stand
Dimensions (WxDxH) 27.1 cm x 55 cm
Adjustable Height 7-10 cm
Adjustments Height
Weight 2 kg
Recommended Use Monitor
Recommended Display Size 32"
Max Load Weight 15 kg
Material Plastic, MDF
Colour Black
Package Content 4 x rubber feet, 4 x stand risers, 4 x riser extenders
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Monitor R...
£29.26
