StarTech.com Monitor Riser Stand for up to 34" Monitors
£58.46
Delivery:
Standard: 1-3 working days
Key features
  • Free up space on your desktop by raising your monitor 5.1" (13 cm) off the desk surface
  • Sturdy clamp-on shelf attaches easily onto surface edges up to 1.3" (33 mm) thick, including desks, tables, counters and other flat surfaces
  • Supports computer monitor up to 34" with weight capacity up to 44 lb. (20 kg)
Product codes
Maximize your desktop space and elevate your screen for more comfortable viewing with this monitor riser. It clamps on easily to your desk to open up more surface space, giving you an extra wide monitor shelf with a minimal footprint. The attractive black finish complements your office decor.
Enjoy an organized, clutter-free workspace with this space-saving monitor stand, 25.6" x 10.2" (65 cm x 26 cm). The extra wide monitor shelf provides ample room to hold your monitor and desk accessories. Use the large area underneath to store a full-size keyboard and other items, to keep everything within easy reach.
With its heavy-duty base and sturdy platform, the clamp-on monitor shelf provides stable support for a single monitor up to 34", with a maximum weight capacity up to 44 lb. (20 kg). You can also use the monitor stand to raise your laptop or printer, freeing up desk or counter space underneath. The integrated cable management slots keep cables organized and out of view.
The office desk monitor shelf offers fast and easy set up, with a C-clamp that attaches easily on to desk surfaces up to 1.3" (33 mm) in thickness. It offers a great space-saving solution without permanently altering your desk or table surface.
Product Description StarTech.com Monitor Riser Stand - Clamp-on Monitor Shelf for Desk - Extra Wide 25.6" (65 cm) For up to 34" Monitors - Black (MNRISERCLMP) - mounting kit - for Monitor - black
Product Type Mounting kit - desk-mountable
Dimensions (WxDxH) 65 cm x 26 cm x 13 cm
Weight 4 kg
Recommended Use Monitor
Recommended Display Size Up to 32"
Max Load Weight 20 kg
Colour Black
Package Content 4 x washers, hex key, desk clamp, 4 x screws
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£58.46
