StarTech.com Monitor Wall Mount - Aluminum
Key features
  • Mount your monitor or flat-screen TV on a wall to save space and easily share your screen
  • Supports a 13’’ - 27’’ monitor up to 33 lb. (15 kg)
  • Swivels +45° / - 45° to provide viewing flexibility
Product codes
Free up space by mounting your monitor, and adjust its position easily with this pivoting wall mount. Wall-mount your computer monitor or flat-screen TV to free up space on your desk or table. This monitor wall mount supports displays up to 27". It swivels and tilts to enable you to adjust the angle of your screen and provide viewing flexibility.
The monitor wall mount helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. (15kg) in weight. It's ideal for many different applications, including business meeting rooms, healthcare or financial settings. The monitor wall mount works well in office settings or workspaces that back against a wall.
The monitor wall mount makes it easy to change your screen position, so you can work more comfortably. It swivels +45° / - 45°, enabling you to move your screen easily to the left or right. It also tilts freely +45° / - 45°, which makes it easy to adjust the angle of your display up or down.
The aluminum monitor wall mount features slide-in wall plate construction for easy installation. To help keep your work area free of clutter, the monitor arm also features a cable clip that keep your cables neatly out of sight.
Product Description StarTech.com Monitor Wall Mount - For VESA Mount Monitors & TVs up to 27in - wall mount
Product Type Wall mount
Tilt -45° to 45°
Pan -45° to 45°
Adjustments Tilt, swivel
Recommended Use Monitor / flat panel
Recommended Display Size 13"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm, 50 x 50 mm
Max Load Weight 15 kg
Material Aluminium
Package Content 4 x M5x14 screws, 4 x washers, hex key, 4 x M4x14 screws, 2 x screws, 2 x wall screws
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Monitor W...
