StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed US...
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub
£88.88
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Four USB 3.0 compliant ports with support for speeds up to 5 Gbps, while still compatible with USB 2.0/1.x devices at the same time
  • An all metal chassis, built-in surface mounting brackets and choice of power input method makes this versatile enough for almost any environment
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Type: USB Hub
  • Interface: SuperSpeed USB 3.0
  • Speed: 5Gbps
  • Ports: 4
  • Form Factor: External
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £92.37
Save £1.50
The ST4300USBM Mountable 4-Port Industrial USB Hub (USB 3.0) offers a simple way to expand a systems current USB capability by providing 4 additional external USB 3.0 ports from a single USB 3.0 host connection, with speeds up to 5 Gbps.
Designed for extreme operating environments, this industrial-grade hub provides reliability under almost any condition and can be securely mounted to most surfaces.
Fully compliant with the SuperSpeed USB 3.0 specification, this industrial USB hub is backward compatible with USB 2.0 and 1.x specifications for simultaneous support of older USB peripherals or even older systems without USB capabilities.
Product Description StarTech.com 4-Port USB 3.0 Hub - Industrial USB Expansion Hub with ESD Protection - TAA Compliant - Metal Mountable USB Hub (ST4300USBM) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features Wall mountable
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Power DC 7 - 24 V
Dimensions (WxDxH) 6 cm x 15.2 cm x 2.4 cm
Weight 480 g
Colour Black
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition
Designed For P/N: ITB20D3250, MSDREADU2OTG, PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mountable...
£88.88
