This sturdy, industrial grade USB hub can be wall mounted or installed onto a DIN rail for convenient access to its 4 female USB ports, providing a work area, server room, or industrial area with USB 2.0 connectivity. With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 4 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
Product Description | StarTech.com 4-Port Industrial USB 2.0 Hub with ESD Protection - Mountable - Multiport Hub (ST4200USBM) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 2.0 | Power | DC 7 - 24 V | Dimensions (WxDxH) | 5.7 cm x 11.5 cm x 2.6 cm | Colour | Black | System Requirements | Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003 | Manufacturer Warranty | 2-year warranty | Designed For | P/N: MSDREADU2OTG |
General | |
Enclosure Type | DIN rail mountable |
Subtype | USB |
Status Indicators | Port status, power |
Expansion / Connectivity | |
Interfaces | 4 x USB 2.0 Type A , 1 x USB 2.0 Type B |
Power | |
Voltage Required | DC 7 - 24 V |
Miscellaneous | |
Colour | Black |
Included Accessories | DIN-rail mounting kit |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003 |
Dimensions & Weight | |
Width | 5.7 cm |
Depth | 11.5 cm |
Height | 2.6 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Compatibility Information | |
