StarTech.com Mountable Rugged Industrial 7 Port USB Hub
£77.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A single USB host connection provides 7 additional USB ports with per port surge protection
  • Surface and DIN mounting options and terminal block power input to suit a wide range of industrial applications
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Type: USB Hub
  • Interface: USB 2.0
  • Speed: 480Mbps
  • Ports: 7
  • Form Factor: DIN rail mountable
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £80.75
Save £1.50
Add 7 USB 2.0 ports to your industrial workspace, with support for DIN rail or wall-mounted installation. This sturdy, industrial grade USB 2.0 hub can be wall mounted or installed onto a DIN rail for convenient access to its 7 female USB 2.0 ports, providing a work area, server room, or industrial environment with USB 2.0 connectivity.
With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 7 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
Product Description StarTech.com 7-Port Industrial USB 2.0 Hub with ESD & 350W Surge Protection - Mountable - Multiport Hub (ST7200USBM) - hub - 7 ports
Device Type Hub - 7 ports
Subtype USB
Ports 7 x USB 2.0
Power DC 7 - 24 V
Dimensions (WxDxH) 6.2 cm x 13.3 cm x 3.6 cm
Weight 0.5 kg
Colour Black
System Requirements Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 2003
Designed For P/N: ITB20D3250, MSDREADU2OTG, USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Mountable...
£77.26
