StarTech.com mSATA SSD to 2.5in SATA Adapter Converter
£20.32
21 in stock
Delivery:
Standard: 1-3 working days
  • Type: Adapter
  • Stock Status: In Stock
Product codes
Convert an mSATA SSD into a 7mm high 2.5in SATA 6Gbps Open Frame SSD. Vastly increase system performance by adding the speed of an mSATA SSD in any 2.5" SATA application, with the SAT32MSAT257 mSATA to SATA adapter.
Utilize the full potential of your SATA III controller, with an mSATA SSD reducing your DATA transfer bottle neck with file transfer speeds up to 6 Gbps. mSATA SSDs also save you money by reducing your power consumption over regular platter drives.
Help protect the health of your drive with an open frame design ensuring maximum heat dissipation.
Product Description StarTech.com mSATA SSD to 2.5in SATA Adapter Converter - storage controller - SATA 6Gb/s - SATA 6Gb/s
Device Type Storage controller - internal
Bus Type SATA 6Gb/s
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Channel Qty 1
Dimensions (WxDxH) 7 cm x 10 cm x 0.7 cm
Weight 100 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com mSATA SSD...
£20.32
