StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to S...
StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card
£14.43
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Turn an mSATA host connection into a standard SATA port. The MSAT2SAT3 mSATA to SATA adapter enables you to connect a standard SATA drive to an available mSATA port.
The adapter improves system capacity by enabling an mSATA port to host a larger SATA hard drive (tested up to 4TB). For guaranteed compatibility and performance the adapter is compliant with SATA I/II/III revisions, allowing for transfer speeds up to 6Gb per second.
Product Description StarTech.com mSATA to SATA HDD/SSD Adapter - Mini SATA to SATA Converter - storage controller - mSATA - SATA 6Gb/s
Device Type Storage controller - internal
Bus Type SATA 6Gb/s
Interface mSATA
Data Transfer Rate 6 GBps
Supported Devices Hard drive, solid state drive
Channel Qty 1
Dimensions (WxDxH) 3 cm x 5.1 cm x 0.8 cm
Weight 60 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com mSATA to...
£14.43
