This USB-C multiport adapter supports 4K 30Hz HDMI or 1080p VGA and turns your MacBook Pro, Dell XPS, or other USB-C laptops or tablet into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI or 1080p VGA video output, two USB 3.1 Gen 1 Type-A (5Gbps) ports (including 1x Fast Charge port), a single USB 3.1 Gen 1 Type-C (5Gbps) port, an SD/MicroSD card reader and a Gigabit Ethernet port, all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 12-inch (30 cm) host cable for an extended reach to offer more set up flexibility. USB 3.1 Gen 1 (5Gbps) is also known as USB 3.2 Gen 1 (5Gbps) and USB 3.0 (5Gbps).
Product Description | StarTech.com USB C Multiport Adapter, HDMI 4K 30Hz or VGA Travel Dock, 5Gbps USB 3.0 Hub (USB A / USB C Ports), 100W Power Delivery, SD/MicroSD Slot, GbE, 12" (30cm) Long Attached Cable - USB C Mini Dock - docking station - USB-C 3.2 Gen 1 - VGA, HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C 3.2 Gen 1 | Video Interfaces | VGA, HDMI | Dimensions (WxDxH) | 5.9 cm x 1.4 cm | Weight | 137 g | Colour | Space grey | Networking | Gigabit Ethernet | Manufacturer Warranty | 3-year warranty |
General | |
Depth | 5.9 cm |
Height | 1.4 cm |
Weight | 137 g |
Enclosure Colour | Space grey |
Video | |
Max Resolution Details | 4096 x 2160 - 30 Hz (HDMI only) , 1920 x 1080 - 60 Hz (VGA only) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0, USB 3.1 Gen 1, USB 3.2 Gen 1 |
Expansion / Connectivity | |
Expansion Slots | 1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD |
Interfaces | 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 1 - 24 pin USB-C , 1 x USB-C 3.2 Gen 1 with Power Delivery 3.0 (100 W) - 24 pin USB-C , 1 x network - 1000Base-T - RJ-45 |
Miscellaneous | |
Input Device | SD card reader, microSD card reader |
Cables Included | 1 x USB-C cable - integrated - 30 cm |
Features | Wake on LAN, Preboot Execution Environment (PXE) support, full duplex support, DisplayPort Alt Mode, 100W power delivery |
Compliant Standards | FCC, RoHS, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0 |
System Requirements | |
OS Required | Google Chrome OS, Apple MacOS X 10.9 - 10.15, Apple MacOS X 11.0, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 11 cm |
Shipping Depth | 5.9 cm |
Shipping Height | 1.4 cm |
Shipping Weight | 204 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
