StarTech.com No-Stud TV Wall Mount - Low Profile VESA TV Moun...
StarTech.com No-Stud TV Wall Mount - Low Profile VESA TV Mount 80"
£29.28
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • LARGE 80" NO-STUD TV WALL MOUNT: Low profile TV wall mount supports VESA compatible displays incl. curved TVs up to 80 inch (110 lb/50 kg) w/ support for many VESA patterns; Ideal for unusual stud placement or anywhere on a wall in between studs
  • EASY INSTALLATION: Mount your TV without studs on drywall; The steel frame guides 20 nails into the wall on an angle to increase the load bearing strength; The picture hanger style simplifies the final step of mounting the TV
  • SLIM DESIGN: Studless TV wall mount with a minimal profile of only 1.2" (3cm) is provided with large wall-mounted spacers to give you a choice for the tilting angle (0°/-5°)
  • SECURE MOUNTING: Heavy duty TV wall mount with Automatic Spring Locks and a convenient Quick Release Cord to prevent the flat screen/panel from being easily removed; Ideal for hanging TV on drywall/plaster walls, no drill required
  • COMPATIBILITY: Universal LCD/LED television mount supports LG, Samsung, Sony, Sharp, others (screws/spacers incl) & VESA bracket hole patterns 100x200, 200x200, 200x300, 200x400, 300x200, 300x300, 400x200, 400x300, 400x400, 600x200, 600x300, 600x400
Product codes
No-Stud TV Wall Mount - Slim Design with Tilt - For 37" to 80" Displays
This No-Stud TV Wall Mount enables you to easily and securely mount your display from 37" up to 80" to walls without the need to align the bracket with wall studs. Its steel frame supports displays up to 110lb / 50kg in weight and provides the ability to tilt your display to ensure your application and the ideal viewing angle are aligned.
Easy and Flexible Installation
The studless design of this Universal TV Wall Mount makes it easy for you to mount your TV to a drywall or plaster wall in any boardroom, office, or classroom setup. Simply choose the best mounting location and secure the mounting bracket into the wall (with included nails); no need to drill or look for wall studs. The included Automatic Spring Lock lets you conveniently mount and secure your TV in place.
Low Profile Slim Design
This Low Profile TV Wall Mount is perfect for applications like digital signage, where space and aesthetics are important. With a 1.2" profile from the wall, this Wall Mount TV Hanger provides a professional and clean look.
Tilt your Display
The Hanging TV Wall Mount lets you angle your TV towards your audience. The included wall-mounted spacers give you a choice to change the tilting angle (0°/ -5°) for a comfortable viewing experience.
The FPWHANGER is backed by a StarTech.com 5-year warranty and free lifetime technical support.
Product Description StarTech.com No-Stud TV Wall Mount, Low Profile Heavy Duty VESA TV Wall Mount for up to 80 inch Display (110lb/50kg), Universal Television Wall Mount, Studless Tilting Flat Screen Mount - No Drill TV Mount - mounting kit - for TV - black
Product Type Mounting kit - wall-mountable
Dimensions (WxDxH) 7 cm x 13.3 cm x 3.1 cm
Tilt -5° to 0°
Weight 2.4 kg
Recommended Use TV
Recommended Display Size 37"-80"
VESA Mounting Interface 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
Max Load Weight 50 kg
Material Steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x concrete anchors, 4 x M8x50 screws, 4 x mounting screws
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£29.28
