StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point -...
StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point - 5GHz 802.11a/n PoE-Powered WiFi AP
£61.46
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Less network congestion with greater speed and reliability across outdoor areas with 5Ghz operation at 300Mbps
  • Protection from harsh outdoor elements with weather-resistant housing
  • Deploy a PoE network device in remote locations with a secondary PoE pass-through LAN port
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 300Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11n
  • Compatibility: PC
Product codes
Create or extend the range of a Wireless-N (300Mbps) WiFi network to an outdoor location. The R300WN22OP5G Outdoor Wireless Access Point lets you create or extend the range of a 5GHz Wireless-N (300Mbps) network to an outdoor location, letting your wireless devices connect to your network with enhanced reliability and speed, with less network congestion.
By isolating your wireless network to a 5GHz frequency, your dual-band smartphone, tablet or laptop operates with less interference from other devices on common 2.4GHz networks. For ideal wireless coverage across large outdoor areas, the access point integrates into your existing Wireless A/N or wired network to broadcast a WiFi SSID via a high-power 600mW internal 14dBi 2T2R directional antenna.
This PoE-powered access point includes a passive Power-over-Ethernet injector, so it can be conveniently installed in locations where a typical power outlet is unavailable. Plus, PoE-pass-through via dual RJ-45 LAN ports lets you connect a PoE-capable device at the access points remote location. For versatile outdoor installation, the access point features a weather-resistant housing and is pole and wall-mountable for easier placement.
Supporting wireless data rates up to 300Mbps, the high-performance outdoor AP is compatible with 802.11a/n devices, offers support for WEP, WPA, and WPA2 authentication, incorporates switchable WISP or Bridged operation modes and is configurable through an easy-to-use web-based utility.
Product Description StarTech.com Outdoor 300 Mbps 2T2R Wireless-N Access Point - 5GHz WiFi AP - radio access point
Device Type Radio access point
Form Factor External - outdoor
Processor Atheros AR9344
Data Link Protocol IEEE 802.11a, IEEE 802.11n
Frequency Band 5 GHz
Included Accessories PoE injector
Power Over Ethernet (PoE) Supported PoE
Dimensions (WxDxH) 9.2 cm x 29.1 cm x 5.9 cm
Weight 310 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Outdoor 3...
£61.46
