The CG-ST is a Palo Alto Networks PAN-SFP-CG compatible copper transceiver module that has been designed, programmed and tested to work with Palo Alto Networks brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-TX compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description | StarTech.com Palo Alto Networks CG Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps/1000Mbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (CG-ST) - SFP (mini-GBIC) transceiver module - GigE | Device Type | SFP (mini-GBIC) transceiver module - RJ-45 | Form Factor | Plug-in module | Cabling Type | 1000Base-TX | Data Transfer Rate | 1 Gbps | Data Link Protocol | GigE | Max Transfer Distance | 100 m | OEM Manufacturer Equivalent Part Number | Palo Alto Networks PAN-SFP-CG | Dimensions (WxDxH) | 6.8 cm x 1.37 cm x 1.38 cm | Weight | 15 g | Manufacturer Warranty | Limited lifetime warranty |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Full duplex mode |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-TX - RJ-45 female |
Miscellaneous | |
MTBF | 510,469,759 hours |
Compliant Standards | FCC, RoHS, REACH, MSA |
Dimensions & Weight | |
Width | 6.8 cm |
Depth | 1.37 cm |
Height | 1.38 cm |
Weight | 15 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 9 cm |
Shipping Depth | 11.5 cm |
Shipping Height | 3.1 cm |
Shipping Weight | 50 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
