StarTech.com Palo Alto Networks SX Comp SFP MM Module - 1000B...
StarTech.com Palo Alto Networks SX Comp SFP MM Module - 1000Base-SX
£26.73
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Palo Alto Networks SX guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
The SX-ST is a Palo Alto PAN-SFP-SX compatible fiber transceiver module that has been designed, programmed and tested to work with Palo Alto brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 550 m (1804 ft).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Palo Alto Networks SX Compatible SFP Module - 1000BASE-SX - 1GE SFP 1GbE Multimode Fiber MMF Optic Transceiver - 550m DDM - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
OEM Manufacturer Equivalent Part Number Palo Alto PAN-SFP-SX
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.37 cm
Weight 20 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Palo Alto...
£26.73
