The PEX1000SFP2 PCI Express Gigabit Fiber Network Card lets you connect a PCI Express-based computer directly to a fiber optic network using the Gigabit SFP of your choice.
This Gigabit fiber card adapts to your network fiber connection and distance requirements to offer flexible configuration via an open SFP slot. With broad SFP compatibility the fiber network card lets you use your preferred SFP, giving you more options to connect your computer directly to a fiber network.
With fiber connectivity, your network is not susceptible to electronic interference, often problematic with standard RJ45 copper networks, making this versatile fiber card ideal for secure network setups.
Product Description | StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - network adapter | Device Type | Network adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express x1 | Dimensions (WxDxH) | 1.8 cm x 12.8 cm x 11.8 cm | Weight | 57 g | Cabling Type | Ethernet 1000Base-LX, Ethernet 1000Base-SX | Data Link Protocol | GigE | Data Transfer Rate | 1 Gbps | Compliant Standards | IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.5 - 10.9, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Gigabit Ethernet |
Remote Management Protocol | SNMP 1 |
Status Indicators | Link OK, link/activity |
Features | Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, 48KB packet buffer, PXE 2.1 support |
Expansion / Connectivity | |
Interfaces | 1 - SFP (mini-GBIC) |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Compliant Standards | FCC, RoHS |
Power | |
Power Consumption Operational | 3.2 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.5 - 10.9, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only |
Dimensions & Weight | |
Width | 1.8 cm |
Depth | 12.8 cm |
Height | 11.8 cm |
Weight | 57 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
