StarTech.com PCI Express Gigabit Ethernet Fiber Network Card...
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC
£139.76
Delivery:
Standard: 1-3 working days
Key features
  • Supports full/half-duplex auto-negotiation, auto-MDI/MDIX
  • Jumbo frame support
  • Supports PCI Message Signaled Interrupt (MSI)
  • Preboot Execution Environment (PXE) 2.1
  • Wired / Wireless: Wired
  • Protocol: Gigabit Ethernet
  • Form Factor: Plug-in card
  • Compatibility: Mac, PC
  • Type: Network adapter
Product codes
The PEX1000SFP2 PCI Express Gigabit Fiber Network Card lets you connect a PCI Express-based computer directly to a fiber optic network using the Gigabit SFP of your choice.
This Gigabit fiber card adapts to your network fiber connection and distance requirements to offer flexible configuration via an open SFP slot. With broad SFP compatibility the fiber network card lets you use your preferred SFP, giving you more options to connect your computer directly to a fiber network.
With fiber connectivity, your network is not susceptible to electronic interference, often problematic with standard RJ45 copper networks, making this versatile fiber card ideal for secure network setups.
Product Description StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express x1
Dimensions (WxDxH) 1.8 cm x 12.8 cm x 11.8 cm
Weight 57 g
Cabling Type Ethernet 1000Base-LX, Ethernet 1000Base-SX
Data Link Protocol GigE
Data Transfer Rate 1 Gbps
Compliant Standards IEEE 802.3z, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.5 - 10.9, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com PCI Expre...
£139.76
