StarTech.com PCI Express to Mini PCI Express Card Adapter
£32.90
Delivery:
Standard: 1-3 working days
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
Convert a Mini PCI Express Card into a Standard Desktop PCI Express Card. The PEX2MPEX PCI Express to Mini PCI Express Adapter Card enables Mini PCI Express cards (Mini Cards) to be used in a standard PCI Express card slot. These PCIe Mini Cards, which are typically designed for laptops or small form factor ITX computers, can be used normally inside more conventional desktop computers. The adapter card features a complete PCIe to Mini PCIe pass-through design that eliminates data transfer rate bottlenecks, while the included full and low profile installation brackets makes this adapter card compatible with most computer chassis.
Product Description StarTech.com PCI Express to Mini PCI Express Card Adapter - Mini PCI card adapter - PCIe - PEX2MPEX - Mini PCI card adapter - PCIe
Device Type Mini PCI card adapter
Interface Type PCIe
Dimensions (WxDxH) 2 cm x 7.4 cm x 6.8 cm
Weight 200 g
OS Required Microsoft Windows 7, Microsoft Windows Vista
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com PCI Expre...
£32.90
