StarTech.com PCI Express to PCI Adapter Card
£35.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: PCIe adapter
  • Compatibility: PC
  • Interface: PCI Express
  • Stock Status: In Stock
Product codes
Install half-height/low profile PCI interface cards in a standard PCI Express expansion slot. This PCIe to PCI Adapter Card lets you use low profile PCI expansion cards in a server or desktop motherboard PCI Express slot. Compliant with PCI Express Specification 1.0a and PCI Specification 2.2, the adapter card connects through a PCIe 1x slot to provide a low profile PCI slot in its place. A spare full size bracket for PCI Express card is also included for use in larger desktop or server PCI Express slots.
A versatile solution, the adapter card converts PCIe to PCI or PCI-X; a built-on LP4 power connector links the card to the computer power supply, allowing you to install universal voltage PCI cards (3.3V/5V).
The adapter card offers an economical solution that lets you extend the usability of older or extra PCI Bus cards in newer PCIe capable systems.
To ensure suitable installation in any low profile server or desktop computer, the PCIe/PCI adapter features an innovative bracket design that adapts and secures the low profile PCI or PCI-X card into the converted slot.
Product Description StarTech.com PCI Express to PCI PCIe x1 to PCI slot adapter
Product Type PCIe x1 to PCI slot adapter
Dimensions (WxDxH) 7 cm x 13.5 cm x 2 cm
Weight 52 g
System Requirements Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com PCI Expre...
£35.98
