StarTech.com PCI to PCI Express Adapter Card
£28.18
31 in stock
Delivery:
Standard: 1-3 working days
  • Type: Adapter Card
  • Stock Status: In Stock
Product codes
Install half-height/low profile x1 PCI Express interface cards in a standard PCI expansion slot. The PCI1PEX1 PCI to PCI Express Adapter card lets you use low profile PCIe expansion cards in a server/desktop motherboard PCI slot. The adapter connects through a 32-bit PCI slot to provide a low profile PCIe x1 slot in its place; a spare, full size bracket is included for installation in larger desktop or server expansion slots that can accommodate a full-sized card.
The PCI to PCI Express Adapter features an innovative bracket design that adapts and secures the low profile PCI Express card into the converted slot, ensuring a versatile and economical solution for extending the usability of older PCI motherboards or using low profile PCIe cards that do not have PCI equivalents.
Product Description StarTech.com PCI to PCI Express Adapter Card PCIe x1 to PCI slot adapter
Product Type PCIe x1 to PCI slot adapter
Dimensions (WxDxH) 6 cm x 13.5 cm x 2 cm
Weight 27 g
System Requirements Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com PCI to PC...
£28.18
