StarTech.com PCIe 10Gb Fiber Card SFP+ NIC
£178.81
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Scale your network performance using the 10Gb SFP+ transceiver of your choice and connect your PCIe-enabled server to a 10 Gigabit fiber network. The PEX10000SFP 10 Gigabit Fiber Network Card is a cost-effective solution that delivers fast and reliable 10 Gbps network access at longer distances than copper-based networks. Using the SFP+ transceiver of your choice, you can connect your PCI Express-based server or workstation directly to your 10G fiber optic network.
With the rising strain on network resources due to large file transfers, multimedia content, and an increase in network users, more bandwidth is often required at various levels of your networking infrastructure. With up to 10 Gbps bandwidth, this fiber NIC lets you transfer more data at faster speeds, and is an ideal low-cost addition to your server or high-powered workstation.
The PEX10000SFP adapts to your network fiber connection and distance requirements to offer flexible configuration via an open SFP+ slot, and is compatible with most . With broad SFP+ compatibility this cost-effective fiber card lets you use your preferred SFP+ module, giving you more options to connect your computer directly to a fiber network at greater distances.
For improved operating efficiency, the PEX10000SFP features an energy-efficient Tehuti TN4010 chipset that offers significantly reduced power consumption versus most comparable cards, including the Intel 82599 chipset cards. Superior power efficiency also helps minimize heat generated by the card, in turn avoiding an increase in the operating temperature within your server case.
This versatile 10 Gbps network card offers 16K Jumbo Frame and 802.1q VLAN tagging support, as well as compatibility with VMWare ESXi 5.0/5.1, Microsoft Hyper-V virtualization software, and iSCSI support to combine LAN and SAN functions.
Product Description StarTech.com 10Gb SFP+ Network Card - PCIe 10 Gigabit Ethernet Fiber Network Card w/ Open SFP+ - PCIe x4 10Gb NIC SFP+ Card (PEX10000SFP) - network adapter
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express 2.0 x4
Dimensions (WxDxH) 1.9 cm x 8.3 cm x 12 cm
Weight 43 g
Cabling Type Ethernet 10GBase-LR, Ethernet 10GBase-SR, Ethernet 10GBase-LRM
Data Link Protocol 10 GigE
Data Transfer Rate 10 Gbps
Capacity Jumbo frame size: 16000
Compliant Standards IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3aq
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, VMware ESXi 5.1, VMware ESXi 5.0, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, VMware ESXi 6.0, VMware ESXi 6.5, Microsoft Windows Hyper-V Server, Linux 2.6.24 - 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.10.3 - 10.14
Designed For P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, MASFP10GBLR, MASFP10GBSR, SFP10GBBXDST, SFP10GBBXUST, SFP10GBERST, SFP10GBLRMST, SFP10GBLRST, SFP10GBSRST, SFP10GBZRST, SFP10GERST, SFP10GLRSST, SFP10GLRSTTA, SFP10GSRSST, SFP10GSRXST, TB31PCIEX16
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com PCIe 10Gb...
£178.81
