StarTech.com PCIe Wireless-AC Network Card
£40.78
Delivery:
Product codes
Add advanced 802.11ac Wi-Fi connectivity to a computer or server through a PCI Express slot - with dual band 2.4/5 GHz frequencies and up to 433 Mbps. Upgrade your desktop PC or server to powerful 802.11ac wireless networking. This AC600 network card fits easily into a PCI Express expansion slot to give you dual-band wireless-AC connectivity with speeds up to 433 Mbps.
This wireless-AC adapter lets you add dual-band wireless-AC connectivity to a desktop computer through a PCIe slot. Ideal for your office or home environment, the PCIe Wi-Fi adapter provides a wireless range of up to 100 feet (30m), when paired with an 802.11ac router. It's a cost-effective solution for adding or upgrading to the latest 802.11ac dual-band wireless networking.
The Wi-Fi adapter supports data rates of up to 433 Mbps at 5 GHz, and 150 Mbps at 2.4 GHz. Two detachable external antennas enhance reception and provide more reliable connections.
The versatile USB Wi-Fi adapter gives you dual-band 2.4/5 GHz support, so you can connect easily to the less congested 5GHz wireless network to enjoy lag-free HD video streaming, online gaming, file transfers or other bandwidth-intensive applications. The WMM Quality of Service (QoS) feature quickly prioritizes video streams, Internet calls and online gaming.
This network adapter has a 1T1R (1 transmitter, 1 receiver) antenna design and features two detachable external antennas (dual-band 3dBi). To integrate easily with all of your networking devices, the wireless network adapter is backward compatible with 802.11a/b/g/n networks.
The network card is easy to install in the PCI Express slot on your standard or small form-factor computer. It comes equipped with a standard profile bracket, and includes a low-profile bracket that you can swap in to mount the card in smaller or space-constrained systems.
StarTech.com AC600 Wireless-AC Network Adapter - 802.11ac, PCI Express - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
9.7 cm x 12.1 cm x 2.2 cm
32 g
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac
Data Transfer Rate
433 Mbps
Frequency Band
2.4 GHz, 5 GHz
RTL8821AE - Realtek Semiconductor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
Microsoft Windows Server 2008 R2, Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com PCIe Wire...
£40.78
