This 4-Port USB-C Hub expands the connectivity of a USB-C laptop. This hub features four USB 3.2 Gen 2 (10Gbps) enabled ports, three USB-C and one USB-A, that support high-bandwidth USB peripherals. Connect the attached USB-C cable to a USB Type-C or Thunderbolt 3/4 port, located on the host computer, to enable the quick connection of up to 4 peripherals.
Product Description | StarTech.com 4-Port USB-C Hub, 1x USB-A and 3x USB-C Ports, USB 3.1 10Gbps, Bus Powered, USB Type C Hub with 9.8in (25cm) Wrap-Around Cable, Portable USB-C to USB-A Hub - USB Expansion Hub (HB31CM1A3CB) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 1 x USB 3.2 Gen 2 + 3 x USB-C 3.2 Gen 2 | Performance | Data transfer rate: 10 Gbps | Features | USB powered, plastic housing, downstream | Compliant Standards | USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2 | Dimensions (WxDxH) | 6.2 cm x 13.5 cm x 2 cm | Weight | 89 g | Colour | Space grey | System Requirements | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS | Manufacturer Warranty | 3-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Processor | X VIA Labs / Realtek RTS5423 / VL160 |
Expansion / Connectivity | |
Interfaces | 1 x USB 3.2 Gen 2 Type A , 3 x USB 3.2 Gen 2 Type C |
Miscellaneous | |
Cables Included | 1 x USB-C cable - 25 cm |
Compliant Standards | Plug and Play, FCC, RoHS, WEEE, RCM |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS |
Dimensions & Weight | |
Width | 6.2 cm |
Depth | 13.5 cm |
Height | 2 cm |
Weight | 89 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 17.3 cm |
Shipping Height | 3 cm |
Shipping Weight | 147 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 0 - 85% RH (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 80 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
