StarTech.com Portable 4pt USB-C Hub, 10Gbps
£41.53
Delivery:
Standard: 1-3 working days
Key features
  • HIGH PERFORMANCE: This bus-powered USB 3.2 Gen 2 10Gbps expansion hub features a USB-C host port & multiple downstream ports (3x USB-C & 1x USB-A); Supports up to 15W of power (provided by USB host) that's shared across all connected downstream devices
  • COMPACT & PORTABLE: Small-form-factor 5.3" (13.5cm) x 2.4" (6.2cm) x 0.8" (2cm) durable plastic housing; Built-in 9.8" (25cm) host cable w/wrap-around cable management to prevent tangles during travel from office workstation to boardrooms & work-from-home
  • 4-PORT USB HUB: 3x USB-C & 1x USB-A ports support fast (10Gbps) data transfer speeds; Ideal for connecting USB devices incl. SSDs, thumb drives, storage arrays, webcams, USB A/V capture devices, keyboards & mice; Backward compatible w/ USB 3.0/2.0/1.1/1.0
  • HOST COMPATIBILITY: USB hub works with any USB-C host device incl. laptops & ultrabooks (Lenovo, HP, Dell, Microsoft & Apple Macbook Pro/Macbook Air) and tablets, convertibles & chromebooks (Google Pixelbook, iPad Pro, Samsung Galaxy devices)
  • EASY SETUP: USB expansion hub/splitter is OS independent with native plug-and-play support on all operating systems incl. Windows, macOS, Linux, iPadOS, Chrome OS & Android
  • Ports: 4
Product codes
This 4-Port USB-C Hub expands the connectivity of a USB-C laptop. This hub features four USB 3.2 Gen 2 (10Gbps) enabled ports, three USB-C and one USB-A, that support high-bandwidth USB peripherals. Connect the attached USB-C cable to a USB Type-C or Thunderbolt 3/4 port, located on the host computer, to enable the quick connection of up to 4 peripherals.
Product Description StarTech.com 4-Port USB-C Hub, 1x USB-A and 3x USB-C Ports, USB 3.1 10Gbps, Bus Powered, USB Type C Hub with 9.8in (25cm) Wrap-Around Cable, Portable USB-C to USB-A Hub - USB Expansion Hub (HB31CM1A3CB) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 1 x USB 3.2 Gen 2 + 3 x USB-C 3.2 Gen 2
Performance Data transfer rate: 10 Gbps
Features USB powered, plastic housing, downstream
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
Dimensions (WxDxH) 6.2 cm x 13.5 cm x 2 cm
Weight 89 g
Colour Space grey
System Requirements Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£41.53
