StarTech.com Portable Wireless N WiFi Travel Router / Access...
StarTech.com Portable Wireless N WiFi Travel Router / Access Point / Repeater - USB Powered
Key features
  • Connect all of your wireless devices through a single wired connection, with a portable travel WiFi router
  • Take the router with you anywhere with a pocket-sized, USB-powered design
  • Set up your wireless connection quickly through the easy-to-use web interface
Product codes
Create a wireless hot-spot from a wired network connection to share with any WiFi-enabled device. The AP150WN1X1U Wireless N Travel Router lets you create a portable WiFi hot-spot from a wired network connection to share with all of your wireless devices including tablets, laptops / Ultrabooks and smartphones.
Designed for mobility, this USB-powered pocket router can travel with you anywhere, powered using any USB wall charger or USB port on your laptop / tablet.
Support for several operating modes help you create, share or extend a wireless connection while traveling between hotel rooms, conference centers or boardrooms. Easily choose between Access Point, Router and Repeater / WISP (Wireless Internet Service Provider) modes using the switch on the side of the router and directly configure using any wireless device with a web browser.
Support for Wireless N data rates (backward compatible with 802.11b/g) gives you the speed you need to get your work done faster, with WPA2 authentication to keep your connection secure.
StarTech.com Wireless N WiFi Travel Router / Access Point / Repeater - wireless router - 802.11b/g/n
Wireless router
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Remote Management Protocol
HTTP
Repeating mode, Access Point operational mode, USB powered
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
3.1 cm x 1.5 cm x 8.4 cm
60 g
2 years warranty
Customer reviews
Accessories
Network Adaptors
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Portable...
