StarTech.com Portable Wireless N WiFi Travel Router for iPad...
StarTech.com Portable Wireless N WiFi Travel Router for iPad / Tablet / Laptop - USB Powered
£12.22
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect your mobile devices through a wired connection with a portable travel WiFi router
  • Continue to charge your devices with the integrated charge port
  • Slides over your iPad power adapter for added portability
Product codes
Create a wireless hot-spot from a wired network connection to share with any Wifi-enabled device. The R150WN1X1T Wireless N Travel Router lets you create a portable wireless hot-spot from a wired network connection, or an existing wireless network to share with all of your WiFi-enabled devices including tablets, laptops / Ultrabooks, or smartphones.
Support for several operating modes help you create, share or extend a wireless connection while traveling between hotel rooms, conference centers or boardrooms. The travel WiFi router offers a pocket-sized, USB-powered design with support for Wireless N data rates (backward compatible with 802.11b/g networks).
Directly configurable using any wireless device with a web browser, the travel router supports several additional operation modes including: WISP (Wireless Internet Service Provider - AP & Client) which lets you share an existing WiFi connection with multiple devices, or WiFi repeater mode which extends the coverage area of an existing wireless network to avoid dead spots.
The USB-powered wireless router is designed to fit directly over your iPad wall charger. For other USB wall chargers or an available USB port on a laptop, we've included a USB extension cable to power the device. The portable router also offers a front USB charge port, allowing you to charge your devices as needed.
StarTech.com Portable Wireless N WiFi Travel Router for iPad w/ Charge Port - wireless router - 802.11b/g/n
Wireless router
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Remote Management Protocol
HTTP
Repeating mode, Access Point operational mode, USB powered
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
White
4.8 cm x 5.5 cm x 3.4 cm
335 g
2 years warranty
Customer reviews
Accessories
Network Adaptors
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Portable...
£12.22
