StarTech.com Premium digital audio cable (optical) - SPDIF -...
StarTech.com Premium digital audio cable (optical) - SPDIF - 6.1 m-TOS Link
£23.30
Select:
5 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Rich, detailed, optical digital sound, even at extreme volumes
  • Guaranteed reliability
  • Type: Audio
  • Length: 6.1m
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Deliver high quality optical digital sound, with no signal interference. The TOSLINK20 20ft Toslink Optical Digital Audio Cable provides clean, accurate sound, with no distortion or signal interference, offering a high quality connection between your PC audio card and stereo/home theater system.
The TOSLINK20 is constructed for maximum durability, for dependable, long-lasting connections.
Product Description StarTech.com 20 ft. (6.1 m) Digital Optical Audio Cable - Toslink Digital Optical SPDIF - Premium - Male/Male - Optical Audio Cable (TOSLINK20) - digital audio cable (optical) - SPDIF - 6.1 m
Cable Digital audio cable (optical) - SPDIF
Technology Fibre optic
Length 6.1 m
Connector TOSLINK - male
Connector (Second End) TOSLINK - male
Designed For P/N: FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, PEXSOUND7CH, STNDMTV70
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: 3ZJM 042952
£8.67
product
Ref: 3ZJM 042952
Accessories
Packaging
Functional
Software
Manuals
£8.67
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Premium d...
£23.30
