StarTech.com Quad-Monitor Stand - For up to 32" VESA Mou...
StarTech.com Quad-Monitor Stand - For up to 32" VESA Mount Monitors
£188.71
Delivery:
Standard: 1-3 working days
Key features
  • Save space by mounting four VESA mount monitors (75x75, 100x100) up to 32" each, on a free-standing base
  • Heavy-duty quad-monitor stand supports four monitors up to 17.6 lb./8 kg per display
  • Four articulating arms extend up to 16.6" (42.2 cm) and provide a wide range of motion
  • Stock Status: In Stock
Product codes
Boost productivity and customize your workspace with this quad-monitor stand, suspending four monitors above your desk. Enjoy optimum viewing with four articulating monitor arms, providing a wide range of motion. The free-standing base gives you flexibility in placing your setup within your workspace.
Constructed of aluminum and steel, the heavy-duty four-monitor stand lets you set up your workspace for optimum productivity. The monitor stand supports four VESA mount (75x75, 100x100) monitors up to 32" each, with a maximum weight capacity of up to 17.6 lb./8 kg per display.
Create a multi-monitor workstation that works best for you. Take advantage of four-screen efficiency for financial analysis, web coding, video editing or many other applications. Customize your setup by adjusting your display height, position and viewing angles for an ergonomic workspace. The swiveling arms provide maximum viewing flexibility.
Place your monitors at the ideal height. Simply adjust the display height along the 34" (864 mm) pole. Align your monitors with the micro-adjustment feature.
The four-screen monitor stand lets you extend the articulating arms up to 16.6" (42.2 cm) to position your monitors in the ideal position. Tilt your monitors +90/-40 degrees and swivel 360 degrees. Rotate your displays 360 degrees for portrait or landscape viewing.
Neatly route your cables with the cable-management channels.
Product Description StarTech.com Quad-Monitor Stand - For up to 32" VESA Mount Monitors - stand (adjustable arm)
Product Type Stand (adjustable arm) - desktop stand
Dimensions (WxDxH) 34.8 cm x 55.3 cm x 12.5 cm
Tilt -40° to 90°
Rotation 360°
Swivel 360°
Adjustments Height
Weight 6.9 kg
Recommended Use 4 monitors
Recommended Display Size 32"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 8 kg
Material Aluminium, steel
Package Content 16 x washers, hex key (3mm), 4 x VESA monitor mounts, hex key (6mm), 2 x cable-management clips, lower pole, base, upper pole, pole connector, 4 x swivel arms, 16 x M4x16 screws, 16 x M4x12 screws, 16 x M5x16 screws, 16 x M5x12 screws, 16 x M4x20 screws, 16 x M5x20 screws, 32 x spacers, 2 x shoulders
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Quad-Moni...
£188.71
