StarTech.com Quad Monitor Stand - Steel
£184.90
Delivery:
Standard: 1-3 working days
Key features
  • Free-standing monitor stand supports four monitors, each up to 27” (686 mm) in size and 17.6 lb. (8 kg) in weight
  • Solid steel base and heavy-duty steel and aluminum construction for optimum support
  • Micro-adjustment enables level viewing of four monitors
Product codes
Increase productivity and free up space by mounting four monitors to this attractive desktop stand. This free-standing quad-monitor stand saves you valuable desk space and boosts productivity, by creating a more comfortable and ergonomic workspace. Constructed of steel and aluminum, the robust monitor stand suspends up to four monitors above your desk or other work surface.
Clear up your desk surface and enjoy an ergonomic workspace. This computer monitor stand supports four displays that are each 13" to 27" (330 to 686 mm) in size and up to 17.6 lb. (8 kg) in weight.
With its dual-crossbar design, this monitor stand lets you mount four monitors onto a single base that rests on your desktop. This gives you more surface area on your desk for personal devices or for physical tasks like reviewing paper documents. And, adding extra monitors gives you ample screen space to simplify multitasking - using four displays makes it easier to reference material on several screens while working on another, saving you the time and hassle of having to flip back and forth between documents.
The monitor stand enables easy adjustment of your screen position, with +45°/-45° swivel, +45°/-45° tilt, and full 360° rotation. The structure offers smooth, effortless rotating and positioning in any direction, so it's easy to reduce glare and find the ideal viewing angle. The micro-adjustment features enable the level alignment of your four monitors. You can also adjust the height of the monitors along the 32.2" (818 mm) pole.
The quad-monitor stand is engineered with heavy-duty steel and aluminum and features a solid steel base. The surface finish features a powder coating to resist scratches. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
Product Description StarTech.com Quad Monitor Stand - Steel - For VESA Mount Monitors up to 27in - stand
Product Type Stand - desktop stand
Dimensions (WxDxH) 31.6 cm x 81.8 cm x 88.5 cm
Tilt -45° to 45°
Pan -90° to 90°
Rotation 360°
Adjustments Height, tilt, swivel, rotation
Recommended Use 4 monitors
Recommended Display Size 13"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 8 kg
Material Aluminium, heavy duty steel
Colour Black
Package Content Mounting hardware
Designed For P/N: ACCSMNT
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Quad Moni...
£184.90
