This USB-C Gen 2 10Gbps docking station turns your USB-C or Thunderbolt 3 MacBook Pro, Windows laptop, and Chromebook into a powerful workstation. A USB 3.2 Gen 2 Type-C dock features everything you need, from quad HDMI or DisplayPort video outputs up to 4K 60 Hz to 10Gbps USB-C & USB-A downstream peripheral ports to 100W Power Delivery.
Product Description | StarTech.com USB-C Dock, 4K 60Hz Quad Monitor DisplayPort & HDMI, Universal USB C Docking Station with 100W Power Delivery Charging, USB Hub w/ 1x USB Type-C & 3x USB-A, Ethernet, Audio - Thunderbolt 3 Compatible (DK31C4DPPDUE) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 - 4 x DP, 4 x HDMI - GigE | Product Type | Docking station | Docking Interface | USB-C 3.2 Gen 2 / Thunderbolt 3 | Video Interfaces | 4 x DP, 4 x HDMI | Dimensions (WxDxH) | 9 cm x 21.5 cm x 4.65 cm | Weight | 330 g | Colour | Black, space grey | Localisation | United Kingdom, Europe | Networking | Gigabit Ethernet | Power | Power adapter AC 110-240 V | Manufacturer Warranty | 3-year warranty |
General | |
Width | 9 cm |
Depth | 21.5 cm |
Height | 4.65 cm |
Weight | 330 g |
Enclosure Colour | Black, space grey |
Video | |
Max Resolution Details | 5120 x 2880 (Dual Display (DisplayPort 1.2)) , 3840 x 2160 - 60 Hz (Quad Display) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 4 x display / video - DisplayPort output - 20 pin DisplayPort , 4 x display / video - HDMI output - 19 pin HDMI Type A , 1 x audio - headphones/microphone - mini-phone 3.5 mm 4-pole , 1 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) - 24 pin USB-C , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB-C cable - external - 1 m |
Features | Security lock slot (cable lock sold separately), wake on LAN, Preboot Execution Environment (PXE) support, 100W power delivery |
Security Slot Type | Kensington security slot |
Compliant Standards | USB-IF, DisplayLink Plug and Display, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, USB Power Delivery |
Power | |
Power Device | Power adapter |
Voltage Required | AC 110-240 V |
System Requirements | |
OS Required | Google Chrome OS 61 or later, Apple macOS 10.14 - 11.0, Microsoft Windows 10 / 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 23.1 cm |
Shipping Height | 9.7 cm |
Shipping Weight | 360 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
