StarTech.com Quick Charge 2.0 wall charger
Colours:
Product codes
Fast charge your mobile devices at home or while you're traveling. Are you planning an international business trip? Do you need a wall charger that will charge your devices in time for all of your meetings and presentations?
Now you can charge your mobile devices in less time, and ensure you're always prepared even while you're away, without having to worry about whether or not the adapter you use at home will work overseas. This versatile travel charger ships with interchangeable power plugs that let you plug in and charge your devices nearly anywhere you go around the world.
Plus, when connected to devices that support Quick Charge 2.0, it delivers more power than conventional chargers in order to make sure you are up and running faster.
The wall charger includes a universal power adapter, which lets you plug in to any electrical socket almost anywhere in the world. So, no matter where you're traveling to, you can rest assured that you'll be able to keep your mobile devices charged and ready to use.
Charge your device 75% faster and be ready when you need to be. Qualcomm tests for Quick Charge 2.0 have shown that a 3300mAH battery in a compatible smartphone charges from 0% to 60% in 30 minutes. Conventional charging only charged up to 12% in the same amount of time.
The charger also works with devices that do not support Quick Charge 2.0, charging these devices at regular speeds.
The portable USB wall charger features a folding North American plug that tucks away nicely to fit inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory for any carry-on. Plus, you can easily throw in the correct international plug for your destination and you're all set to go.
Once you land you can swap out the plugs and be ready to charge in the airport, in your hotel room or just about anywhere you can find a wall outlet.
Some mobile devices such as certain Samsung and BlackBerry devices use proprietary power connections which are not compatible with aftermarket chargers. Please consult the manufacturer's documentation to ensure compatibility with the USB1PACVWH.
StarTech.com USB wall charger - Quick Charge 2.0 - 110V/220V Charger - power adapter
Power adapter
130 g
White
Output Connector Type
USB
AC 110-240 V
Fast Charge Technology
Qualcomm Quick Charge 2.0
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Quick Cha...
