StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Coole...
StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
£6.13
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Cools your PC, increasing dependability and extending component lifetime
  • Exhausts hot air out of a PC, increasing dependability and extending component lifetime
Product codes
This 70mm TX3 Dual Ball Bearing CPU Cooler Fan is a cost-effective replacement fan for standard CPUs as well as many different types of 1U or low profile CPU coolers that use a 70mm fan.
For peace of mind, the CPU cooling fan features a Tachometer pin on the TX3 motherboard connector that provides the host system with fan operating status, while a dual ball bearing design helps provide smooth operation and longer (fan) lifespan.
StarTech.com Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan - case fan
Case fan
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
3500 rpm
Air Flow
21.3 cfm
Power Connector
3-pin plug
Product Material
Plastic
Fan speed monitoring
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Replaceme...
£6.13
