StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter
£11.20
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
The DB92422 DB 9 to Terminal Block adapter converts an RS-422 or RS-485 DB 9 male serial connector to a terminal block connector.
The 5-pin 3.5mm Terminal Block connector supports screw-type wiring to meet the standard for industrial wiring applications.
Product Description StarTech.com RS422 RS485 Serial DB9 to Terminal Block Adapter - Serial adapter - 5 pin terminal block to DB-9 (M) - black - DB92422 - serial adapter
Type Serial adapter
Connector 5 pin terminal block
Connector (Second End) 9 pin D-Sub (DB-9) - male
Colour Black
Manufacturer Warranty 1-year warranty
Designed For P/N: PCI2S232485I, PCI2S4851050
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com RS422 RS4...
£11.20
