Connect a 2.5in or 3.5in SATA hard drive to your computer through USB 3.0 or eSATA. The SATDOCKU3E USB 3.0/eSATA to SATA Hard Drive Docking Station provides quick and easy access to a 2.5in or 3.5in SATA hard disk drive (HDD) or solid state drive (SSD) through either eSATA or USB connectivity, making it compatible with almost any system.
The HDD docking station supports large capacity drives (tested with up to 4 TB 3.5" and 1 TB 2.5" drives), which enables you to greatly enhance your computer's storage/backup capabilities.
The hard drive dock offers eSATA or USB 3.0 host connections (3 Gbps, 5 Gbps bandwidth respectively), and is backward compatible with USB 2.0 (up to 480 Mbps) connections to the host computer.
To simplify HDD installation and swapping drives in and out of the dock, the SATDOCKU3E features a top slot-loading design, for easy access.
| Product Description | StarTech.com SATA Hard Drive Docking Station eSATA USB 3.0 to SATA HDD Dock - HDD docking station - SATA 3Gb/s - eSATA 3Gb/s, USB 3.0 | Device Type | HDD docking station - external | Bays | 1 | Bus Type | eSATA 3Gb/s, USB 3.0 | Colour | Black | Expansion Bays | 1 x top accessible - 2.5" / 3.5" shared | Hard Drive Form Factor Compatibility | 2.5" / 3.5" shared | Features | Power indicator | Interface | SATA 3Gb/s | Data Transfer Rate | 300 MBps | Supported Devices | Hard drive, solid state drive | Max Storage Devices Qty | 1 | Product Material | Plastic | Power | AC 100/230 V (50/60 Hz) | System Requirements | Apple MacOS X 10.2 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits) | Dimensions (WxDxH) | 14.2 cm x 8 cm x 8 cm | Weight | 400 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: USBDUP15 |
General | |
| Bays | 1 |
| Host Bus | eSATA 3Gb/s, USB 3.0 |
| Colour | Black |
Storage Controller | |
Expansion / Connectivity | |
| Interfaces | 1 x SATA 3Gb/s - SATA combo |
| Connections | 1 x USB 3.0 - 9 pin USB Type B , 1 x eSATA - 7 pin external Serial ATA |
Miscellaneous | |
| Cables Included | 1 x USB 3.0 cable - external , 1 x eSATA cable - external |
| Features | LED indicator |
| Compliant Standards | FCC, RoHS |
Power | |
| Type | Power adapter |
| Voltage Required | AC 100/230 V (50/60 Hz) |
Software / System Requirements | |
| OS Required | Apple MacOS X 10.2 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits) |
Manufacturer Warranty | |
| Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
| Width | 14.2 cm |
| Depth | 8 cm |
| Height | 8 cm |
| Weight | 400 g |
Environmental Parameters | |
| Min Operating Temperature | 5 °C |
| Max Operating Temperature | 40 °C |
| Humidity Range Operating | 8 - 90% |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
