StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter fo...
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks
£20.82
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
The SAT2IDEADP SATA to IDE hard drive adapter allows for 2.5in/3.5in IDE-based (PATA) hard drives (HDD) to be used in most StarTech.com SATA-based HDD docking stations and drive duplicators. The unique mounting style of the SATA/IDE adapter enables it to be easily mounted to IDE/ATA hard drive and inserted into SATA hard drive dock bay, for quick and easy retrieval of data from older HDDs while its all- metal construction ensures maximum durability. The SAT2IDEADP hard drive adapter works with most StarTech.com SATA HDD Docking Stations and Duplicators, including: SATADOCK22UE, SATDOCK2UEGB, SATDOCK22RE, SATDOCK22R, SATDOCKU3S, SATADOCKU2, SATADOCKU2E, SATDOCK4U2E, SATDOCK4U3E, SATDOCKCRH, SATDOCKU2EGB, SATDOCKU2GB. Fully compatible with both 2.5in and 3.5in form factor hard drives and up to ATA-133 (133 MBps), this versatile HDD adapter can also be used to install IDE hard drives into SATA-only desktop computers, or many other scenarios that require an IDE HDD be connected through SATA.
Product Description StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks - storage controller - ATA-133 - SATA
Device Type Storage controller - internal
Bus Type SATA
Hard Drive Form Factor Compatibility 2.5", 3.5"
Interface ATA-133
Data Transfer Rate 133 MBps
Supported Devices Hard drive
Channel Qty 1
Dimensions (WxDxH) 7.8 cm x 10.1 cm x 2.6 cm
Weight 104 g
Designed For P/N: SATADOCKU2GB, SATDOCKU2EU, SATDOCKU2EEU, SATDUPUEGB, SATDUPUEEU, SATDOCK2UEEU, SATDOCK4U3E, SATDOCK4U2E, SATDOCK22RE, SATDOCKU3S, SATDOCKCRHGB, SATDOCKCRH, SATDOCK22R, SATDOCKU2GB, SATDOCKU2EGB, SATDOCK2UEGB, SATADOCKU2E, SATADOCKU2, SATADOCK22UE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com SATA to 2...
£20.82
