StarTech.com SATA to LP4 Power Cable Adapter with 2 Additiona...
StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4
£5.43
32 in stock
Delivery:
Standard: 1-3 working days
  • Length: 15cm
  • Stock Status: In Stock
Product codes
Power up to 3 devices using a SATA power connector from the computer power supply.
The LP4SATAFM2L SATA to LP4 Power Cable lets you power an IDE (LP4-connected) drive using a SATA power connector from the computer power supply. The adapter features two additional LP4 power connectors, offering the versatility to connect two additional (LP4 connected) drives (CD/DVD-ROM, HDD, etc.) using the same single connection to the computer power supply.
This high quality LP4/SATA power adapter cable is expertly designed for durability.
Product Description StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 - power adapter - 15 cm
Type Power adapter
Length 15 cm
Connector 3 x 4 PIN internal power - female
Connector (Second End) 15 pin Serial ATA power - male
Colour Black
Designed For P/N: SATSASBAY425, ATX2POWER430, ATX2POWER530
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com SATA to L...
£5.43
