Connect your HDMI Display to an SDI Video Source. The SDI2HD 3G SDI to HDMI converter enables you to turn a 3G SDI video signal into an HDMI video output. The adapter features a built-in 3G SDI daisy chain port, giving you the ability to further extend the SDI source to up to 755ft (230m) over standard coaxial cable, for large scale HD-SDI video broadcasting distribution.
To ensure you maintain perfect high-definition video quality the SDI-HDMI converter features supports resolutions up to 1080p, allowing you to convert SDI to HDMI without sacrificing video quality.
For hassle-free installation, the SDI to HDMI converter offers a plug-and-play solution that includes pre-installed mounting brackets and requires no software or driver installation.
Product Description | StarTech.com SDI to HDMI Converter - 3G SDI to HDMI Adapter with SDI Loop Through Output - video converter - black | Device Type | Video converter | Max Resolution | 1920 x 1200 | Interfaces | 1 x HDMI output - 19 pin HDMI Type A , 1 x 3G-SDI input - BNC , 1 x 3G-SDI output - BNC | Dimensions (WxDxH) | 10 cm x 7 cm x 2.5 cm | Enclosure Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Interfaces | 1 x HDMI output - 19 pin HDMI Type A - female , 1 x 3G-SDI input - BNC - female , 1 x 3G-SDI output - BNC - female |
System Requirements | |
Voltage Required | AC 120/230 V |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Width | 10 cm |
Depth | 7 cm |
Height | 2.5 cm |
Weight | 202 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 90% (non-condensing) |
