StarTech.com SDI to HDMI Converter – 3G SDI to HDMI Adapter w...
StarTech.com SDI to HDMI Converter – 3G SDI to HDMI Adapter with SDI Loop Through Output
£188.02
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect your HDMI Display to an SDI Video Source. The SDI2HD 3G SDI to HDMI converter enables you to turn a 3G SDI video signal into an HDMI video output. The adapter features a built-in 3G SDI daisy chain port, giving you the ability to further extend the SDI source to up to 755ft (230m) over standard coaxial cable, for large scale HD-SDI video broadcasting distribution.
To ensure you maintain perfect high-definition video quality the SDI-HDMI converter features supports resolutions up to 1080p, allowing you to convert SDI to HDMI without sacrificing video quality.
For hassle-free installation, the SDI to HDMI converter offers a plug-and-play solution that includes pre-installed mounting brackets and requires no software or driver installation.
Product Description StarTech.com SDI to HDMI Converter - 3G SDI to HDMI Adapter with SDI Loop Through Output - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI output - 19 pin HDMI Type A , 1 x 3G-SDI input - BNC , 1 x 3G-SDI output - BNC
Dimensions (WxDxH) 10 cm x 7 cm x 2.5 cm
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com SDI to HD...
£188.02
