StarTech.com Secure tablet stand, Desk/wall
£141.31
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • SECURE TABLET STAND: This black enclosure is secured by lock and key, preventing the removal of the tablet and access to the ports/buttons. The POS tablet stand supports 10.2" iPad (7/8th gen), 10.5" iPad Air (3rd gen), or 10.5" iPad Pro (2nd gen)
  • THOUGHTFUL DESIGN: An internal path allows for routing of a charging cable, ideal for POS/kiosks, or self-service scenarios. The locking tablet mount features a keyed security lock, two K-slots at the back for enhanced security, and all-steel construction
  • MOUNTING OPTIONS: The tablet holder supports a 100x100 pattern allowing for use with mounts, arms, or stands that support 2.5+ lb (1+ kg). For ease of use and flexibility, an angled bracket is included. Landscape/portrait support for desk or wall-mounting
  • SPECIFICATIONS: VESA 100x100 | 30° Desk/Wall Bracket | Two K-slots| Incl. Protecting Pads, Mounting Screws, and 2 Keys | All-steel | Display Opening 8.5x6.4 in (217.5x164 mm) | Enclosure 12.7x7.1x0.7 in (324x182.5x19 mm) | Bracket 4.9x5.2 in (125x133 mm)
  • STARTECH.COM ADVANTAGE: IT professionals' choice for over 30 years, this TAA compliant iPad tablet stand holder is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance
Product codes
The secure iPad enclosure lets you set up a tablet as a point of sales (POS) system in your business or for secure product displays. It supports the 10.2" iPad (7/8th gen), 10.5" iPad Air (3rd gen), 10.5" iPad Pro (2nd gen), or other 10.2"/10.5" tablets.
Product Description StarTech.com Secure Tablet Stand, Anti Theft Universal Tablet Holder for Tablets up to 10.5", Lockable Tablet Stand for Desk/ K-Slot Compatible, VESA Mount, Wall Mount Tablet Enclosure - Security POS Tablet Stand (SECTBLTPOS2) - stand - for tablet - black
Product Type Stand - wall-mountable, desktop, VESA bracket mounting - lockable
Dimensions (WxDxH) 32.4 cm x 18.2 cm x 1.9 cm
Rotation 180°
Weight 1.9 kg
Recommended Use Tablet
Recommended Display Size 10.5"
VESA Mounting Interface 100 x 100 mm
Max Mounting Pattern Size 100 x 100 mm
Material Steel
Colour Black
Package Content 2 keys, 4 x M4x10 screws, tablet enclosure, 2 x felt tape (200mm x 5mm), 2 x felt tape (150mm x 10mm), 4 x EVA pads (20mm x 15mm x 3mm), 2 x EVA pads (45mm x 15mm x 2mm), 2 x foam blocks (100mm x 25mm x 20mm), 2 x foam blocks (100mm x 15mm x 12mm), M2.5 hex key, 3 x 5x20m self tapping screws, 3 x washers (small), 2 x washers (large), 4 x rubber pads
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£141.31
