StarTech.com Serial DB9 RS232 Extender over Cat 5 - Up to 330...
StarTech.com Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters)
£93.64
Delivery:
Standard: 1-3 working days
Key features
  • Provides you with flexibility when choosing the location of your serial peripherals by dramatically increasing the maximum RS232 serial cable length
  • Pure hardware design, no software or drivers required, ensuring a simple plug and play installation
  • Enables use of separate control rooms away from harsh environmental conditions where serial devices may be located
  • Type: Extender
  • Stock Status: In Stock
Product codes
The RS232EXTC1GB Serial over Cat 5 Extender allows you to increase the distance of your RS232 Serial connection by up to 1000 meters (3300 feet), giving you the ability to connect serial peripheral devices up to a kilometer away from your system - an incredible 65x greater than normal RS232 serial cable length restrictions would permit.
The Extender is a cost-effective serial extension solution and completely hardware-based, eliminating the need to install additional software, allowing for a completely plug and play installation. The hardware can be setup in minutes, using Cat 5 or better Ethernet cabling.
Perfect for use in industrial monitoring and control, POS, security, medical, and traffic flow applications, the RS232 Serial over Cat 5 extender maintains the RS232 standard with support for data transfer rates of up to 230 Kbps.
Product Description StarTech.com Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters) - serial port extender
Device Type Serial port extender
Form Factor External
Localisation United Kingdom
Data Transfer Rate 230 Kbps
Max Transfer Distance 1 km
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Serial DB...
£93.64
