StarTech.com Shielded Cat 6a Keystone Jack - RJ45 Ethernet Ca...
StarTech.com Shielded Cat 6a Keystone Jack - RJ45 Ethernet Cat6a Wall Jack White - 110 Type
£7.24
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com 2-year warranty
  • Helps keep Near End Crosstalk (NEXT) well within acceptable limits, with a shielded design
  • Type: Modules
  • Stock Status: In Stock
Product codes
Terminate your shielded Cat6a cables at standard wall plates. The C6AKEY110WH Cat 6a Keystone Jack is designed to snap into wall plates, patch panels, and surface connection boxes for quick, seamless deployment.
Meeting and exceeding the international standard ISO / IEC 11801 and the ANSI/TIA-568-C.2 requirements, this RJ45 keystone jack provides the perfect solution for your Ethernet networks.
Product Description StarTech.com Shielded Cat 6a Keystone Jack - RJ45 Ethernet Cat6a Wall Jack White - 110 Type - RJ45 (F) to 110 Punch Down Shielded (C6AKEY110WH) - modular insert
Product Type Modular insert - CAT 6a
Dimensions (WxDxH) 2.1 cm x 3.81 cm x 1.6 cm
Weight 15.5 g
Colour White
Port Qty 1 port
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Shielded...
£7.24
