This single monitor stand enables you to raise your monitor off your desk or table to save space while increasing your productivity. With its durable aluminum construction and a sturdy base (7.8"x9.4" / 200mm x 240mm), it can support VESA compatible displays up to 32" and up to 15.4lb / 7kg in weight. The power coated black semi-gloss finish on the support column provides a professional and modern look that will match your monitor and workstation. Please refer to our technical specifications section for more information on the different aspect ratios supported.
Product Description | StarTech.com Free Standing Single Monitor Mount, Height Adjustable Monitor Stand, For VESA Mount Displays up to 32" (15lb/7kg), Ergonomic Monitor Stand for Desk, Tilt/Swivel/Rotate, Black - Universal Monitor Stand - stand - adjustable arm - for Monitor - black | Product Type | Stand (adjustable arm) - desktop stand | Dimensions (WxDxH) | 20 cm x 24 cm x 57 cm | Adjustable Height | 26.5-41.5 cm | Tilt | -15° to 15° | Rotation | 180° | Swivel | -40° to 40° | Adjustments | Height, tilt, swivel, rotation | Weight | 3.6 kg | Recommended Use | Monitor | Recommended Display Size | Up to 32" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 7 kg | Material | Aluminium | Colour | Black | Package Content | 4 x M4x12 screws, 4 x M5x12 screws, hex key (5mm), hex key (6mm), screwdriver, 4 x M4x6 screws, base, 4 washers | Manufacturer Warranty | 5-year warranty |
General | |
Width | 20 cm |
Depth | 24 cm |
Height | 57 cm |
Weight | 3.6 kg |
Colour | Black |
AV Furniture | |
Type | Stand |
Design | Adjustable arm |
Placing / Mounting | Desktop stand |
Cable Management | Integrated cable management |
Rotation | 180° |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 43.5 cm x 27.5 cm x 11.2 cm / 3.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Customer return - item has been opened but is in excellent condition
Slight damage to packaging
Ref: GLRB 046589 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£25.36
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
