StarTech.com Single Monitor Stand
£69.55
11 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • FREE-STANDING SINGLE MONITOR MOUNT : This monitor stand supports a VESA compatible display up to 32" (15.4lb / 7kg); VESA 75x75/100x100mm; Solid rotating base (+/-40°); Powder coated semi-gloss black finish offers a professional and modern look
  • RANGE OF MOTION: Ergonomic monitor mount increases comfort & productivity with +/-15° tilt, +/-180° screen rotation (portrait/landscape); Entire column swivels +/-40°
  • ONE-TOUCH ADJUSTMENT: Universal monitor stand with height adjustable range of 10.4" to 16.3" (265mm to 415mm) from the desk; The spring-assisted LCD monitor stand offers height adjustments by hand using the easy-access lever at the top of the stand
  • STABLE & NON-SLIP: Freestanding computer monitor mount w/ sturdy anti-slip base (7.8"x9.4" / 200mm x 240mm) and small footprint for maximum stability & flexible placement; Also ideal for glass top desks or surfaces where monitor mounts cannot be installed
  • EASY INSTALL: Keyhole pattern allows you to easily hook and mount your desktop/PC monitor for a faster install; Built-in cable management slot in the lower portion of the column for a tidy workspace; Anti-slip rubber pads prevent scratches on desk surface
Product codes
This single monitor stand enables you to raise your monitor off your desk or table to save space while increasing your productivity. With its durable aluminum construction and a sturdy base (7.8"x9.4" / 200mm x 240mm), it can support VESA compatible displays up to 32" and up to 15.4lb / 7kg in weight. The power coated black semi-gloss finish on the support column provides a professional and modern look that will match your monitor and workstation. Please refer to our technical specifications section for more information on the different aspect ratios supported.
Product Description StarTech.com Free Standing Single Monitor Mount, Height Adjustable Monitor Stand, For VESA Mount Displays up to 32" (15lb/7kg), Ergonomic Monitor Stand for Desk, Tilt/Swivel/Rotate, Black - Universal Monitor Stand - stand - adjustable arm - for Monitor - black
Product Type Stand (adjustable arm) - desktop stand
Dimensions (WxDxH) 20 cm x 24 cm x 57 cm
Adjustable Height 26.5-41.5 cm
Tilt -15° to 15°
Rotation 180°
Swivel -40° to 40°
Adjustments Height, tilt, swivel, rotation
Weight 3.6 kg
Recommended Use Monitor
Recommended Display Size Up to 32"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 7 kg
Material Aluminium
Colour Black
Package Content 4 x M4x12 screws, 4 x M5x12 screws, hex key (5mm), hex key (6mm), screwdriver, 4 x M4x6 screws, base, 4 washers
Manufacturer Warranty 5-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition Slight damage to packaging
Ref: GLRB 046589
£27.97
product
Ref: GLRB 046589
Accessories
Packaging
Functional
Software
Manuals
£27.97
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£69.55
