StarTech.com Sit Stand Dual Monitor Arm
£431.06
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Turn your desk into an ergonomic workstation with this sit-stand dual-monitor arm, supporting two monitors up to 24” (with weight capacity of 17.6 lb./8 kg)
  • The work surface has a height adjustment of up to 17.7” (450 mm)
  • Monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column
Product codes
Enjoy a more ergonomic workspace with this dual-monitor sit-stand desk mount. This sit-stand dual-monitor arm transforms your desk or tabletop into a highly productive, ergonomic workstation. The monitor arm features a keyboard tray and easy height adjustment that lets you alternate between sitting and standing, without interrupting your workflow.
Adjust your working position, with one smooth motion. Simply lift the work surface up to 17.7" (450 mm), to elevate both your monitor plus your keyboard and mouse. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column. You can also adjust the tension to your own preference for easy height adjustment.
The versatile monitor arm lets you create a productive dual-monitor workstation, supporting two monitors up to 24" (with weight capacity of 17.6 lb./8 kg). Move the swing arm left or right (from -90° to 90°) and lower or raise the arm (from -30° to 65°) to the ideal position. The VESA mount also rotates up to 360° for portrait or landscape orientation.
The monitor arm features a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) with ample working space. A slide-out tray (8.5 x 8.4" / 217 x 213 mm) holds your mouse, on the left or right. You can tuck the monitor arm away when it's not in use, to free up space. The keyboard tray also folds up to 90°.
The compact sit-stand monitor arm features a grommet assembly and desk-clamp option, to fit easily into your workspace, including space-limited corners.
StarTech.com Sit Stand Dual Monitor Arm - For Two Monitors up to 24in - mounting kit
Mounting kit
Mounting Components
Desk clamp mount, base plate, column, grommet plate, keyboard tray, base, base pad, grommet clamp, keyboard tray cap, crossbar mount
77.32 cm x 94 cm x 89 cm
Tilt
0° to 30°
Pan
-15° to 15°
Rotation
360°
Adjustments
12 kg
Recommended Use
2 monitors
Recommended Display Size
24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
2 x VESA monitor mounts, 4 x washers, 4 x M6x12 screws, hex key (5mm), wrench, hex key (2.5mm), hex key (6mm), 2 x crossbars, 2 x M6x25 screws, adhesive strip, socket driver, clamp screw assembly, 4 x base screws, M8x20 screw, 3 x M6x10 screws, M8x65 screw, 2 x M6x8 screws, 8 x M4x10 screws, 4 x clamp screws, 2 x knobs
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Sit Stand...
£431.06
