StarTech.com Sit Stand Monitor Arm
£346.72
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Turn your desk into an ergonomic workstation with this sit-stand monitor arm, for one monitor up to 24"
  • The work surface has a height adjustment of up to 17.7” (450 mm)
  • Monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column
Product codes
Enjoy a more ergonomic workspace with this sit-stand desk mount. This sit-stand monitor arm transforms your desk or tabletop into an ergonomic workstation. The monitor arm features a keyboard tray and easy height adjustment that lets you alternate between sitting and standing, without interrupting your workflow. Move your workstation up or down, left or right, to meet your needs.
Adjust your position, with one smooth motion. Simply lift the work surface up to 17.7" (450 mm), to elevate both your monitor and keyboard. You can adjust the tension to your own preference. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports one monitor up to 24". The swing arm swivels from -90° to 90° and tilts from -30° to 65° for ideal viewing. The VESA mount also rotates up to 360° for portrait or landscape orientation.
The monitor arm features a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) with ample working space. A slide-out tray (8.5 x 8.4" / 217 x 213 mm) holds your mouse, on the left or right.
To make the most of your workspace, you can tuck the monitor arm away when it's not in use, to free up space. The keyboard tray also folds up to 90°.
The compact sit-stand monitor arm features a grommet assembly and desk-clamp option, to fit easily into your workspace, including space-limited corners.
StarTech.com Sit Stand Monitor Arm - Monitor Arm Desk Mount - VESA Mount - mounting kit
Mounting kit - desktop
Mounting Components
Base plate, column, grommet plate, keyboard tray, washers, monitor arm, clamp bracket, base, base pad
94 cm x 89 cm
Tilt
-30° to 65°
Pan
-90° to 90°
Lift
43.9 cm
Rotation
360°
Adjustments
Recommended Use
Monitor / keyboard
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
7.9 kg
Package Content
4 x M6x12 screws, hex key (5mm), hex key (2.5mm), hex key (6mm), 2 x M6x25 screws, adhesive strip, socket driver, clamp screws, clamp screw assembly, 4 x base screws, M8x20 screw, 3 x M6x10 screws, 4 x M4x10 screws, M6x8 screw, M8x65 screw, VESA monitor mount
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Sit Stand...
£346.72
