StarTech.com Sit-to-stand Workstation - Dual
Product codes
Turn your desk into a sit-stand workspace with easy height adjustment and a dual monitor mount. This dual-monitor sit-to-stand workstation lets you enhance your productivity and comfort, by giving you a dual-display work space that's easy to adjust according to your desired working position.
With one touch, you can switch your position from sitting to standing or vice versa, to keep a balanced level of movement throughout the day. The workstation features an advanced pneumatic spring that makes it easy to raise or lower the platform. Whether you want to sit or stand while you're working, it's easy to adjust the standing desk to match your exact height requirements, instead of selecting from pre-determined heights.
You can also adjust the tension of the spring according to the weight of monitors, laptops and other components on the platform, to make raising or lowering the workstation even easier.
Adding two monitors to a single workstation gives you the additional screen space you need to simplify multitasking and maximize productivity. Using two displays makes it easier to reference material on one display while working on another, saving you the time and hassle of having to flip back and forth between documents.
The monitor arms offer a wide range of motion on several axes, giving you the freedom to place your displays side by side, spread apart, back to back, or anywhere in between. For viewing longer pages or blocks of code without having to scroll down the screen, the dual arm also supports landscape-to-portrait display rotation for each monitor.
Create a more ergonomic work environment at a fraction of the cost of a standing desk. Instead of replacing your conventional seated desk, you can simply place this compact sit-to-stand workstation on your existing work space and clamp the rear of the base to your desk.
The sit-stand workstation lets you optimize your desk area, and it's easy to integrate it into your current layout by simply setting it on your desk, tabletop or other stable work surface (minimum 26 in. depth).
The workstation provides lots of space for writing notes or placing accessories on its base and features a large keyboard tray that accommodates your keyboard and mouse, so it's perfect for any business or home office workspace.
StarTech.com Sit-to-Stand Workstation with Dual Monitor Articulating Arm - mounting kit
Mounting kit - desktop stand
Mounting Components
Tray, surface, base plate, 2 articulating arms, pneumatic spring
68 cm x 66 cm
Tilt
-90° to 90°
Pan
-90° to 90°
Rotation
360°
Adjustments
23.8 kg
Recommended Use
2 LCD displays / keyboard / mouse / notebook
Recommended Display Size
24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8.7 kg
Material
Plastic, steel
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Sit-to-st...
