StarTech.com Sit-to-stand Workstation - Slim
£359.90
Delivery:
Standard: 1-3 working days
  • Accessory Type: Stand
  • Stock Status: In Stock
Product codes
Turn your desk into a sit-stand workspace with a slim monitor mount that features full-motion articulation. This sit-to-stand workstation offers an easy way to enhance your productivity and comfort, by giving you a work space with a built-in articulating monitor mount that's easy to adjust according to your desired working position.
With one touch, you can switch your position from sitting to standing or vice versa, to keep a balanced level of movement throughout the day. The workstation features an advanced pneumatic spring that makes it easy to raise or lower the platform. Whether you want to sit or stand while you're working, it's easy to adjust the standing desk to match your exact height requirements, instead of selecting from pre-determined heights.
You can also adjust the tension of the spring according to the weight of monitors, laptops and other components on the platform, to make raising or lowering the workstation even easier.
For viewing longer pages or blocks of code without having to scroll down your screen, the included monitor stand supports landscape-to-portrait display rotation.
Mounting your displays on a support post above your workstation surface enables you to adjust your display height independently of your sit-to-stand workstation. You can also easily adjust position and viewing angles, for an ergonomic work environment.
Create a more ergonomic work environment at a fraction of the cost of a standing desk. Instead of replacing your conventional seated desk, you can simply place this compact sit-to-stand workstation on your existing work space and clamp the rear of the base to your desk.
The sit-stand workstation lets you optimize your desk area, and it's easy to integrate it into your current layout by simply setting it on your desk, tabletop or other stable work surface (minimum 26 in. depth).
The workstation provides lots of space for writing notes or placing accessories on its base and features a large keyboard tray that accommodates your keyboard and mouse, so it's perfect for any business or home office workspace.
Product Description StarTech.com Sit-to-Stand Workstation with Articulating Monitor Arm - mounting kit
Product Type Mounting kit - desktop stand
Mounting Components Tray, articulating arm, surface, base plate, pneumatic spring
Dimensions (WxDxH) 68 cm x 66 cm
Tilt -65° to 90°
Pan 360°
Lift 59.6 cm
Rotation -90° to 90°
Adjustments Height
Weight 21.5 kg
Recommended Use LCD display / keyboard / mouse / notebook
Recommended Display Size 12"-26"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 11 kg
Material Wood, steel
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Sit-to-st...
£359.90
