StarTech.com Slim USB 3.0 to HDMI External Video Card Multi M...
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p
£53.91
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Minimizes clutter, with a slim design that blends seamlessly with your video cable
  • Ensures smooth, High-Definition video content, using a high bandwidth USB 3.0 connection
  • Ideal for travel with an ultra-portable small footprint and lightweight design
  • Stock Status: In Stock
Product codes
Connect an HDMI display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32HDES Slim USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to HDMI adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to HDMI Adapter - Slim Design - 1920x1200 - video / audio cable - TAA Compliant - HDMI / USB - 19 cm
Cable Video / audio cable - HDMI / USB
Max Output Resolution 1920 x 1200
Length 19 cm
Colour Black
Connector USB Type A - male (input)
Connector (Second End) HDMI - female (output)
Compliant Standards USB 2.0/ USB 3.0
Features 1080p support
Designed For P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Slim USB...
£53.91
