StarTech.com Slim USB 3.0 to VGA External Video Card Multi Mo...
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p
£46.88
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Minimizes clutter, with a slim design that blends seamlessly with your video cable
  • Ensures smooth, High-Definition video content, using a high bandwidth USB 3.0 connection
  • Ideal for travel with an ultra-portable small footprint and lightweight design
  • Stock Status: In Stock
Product codes
Connect a VGA display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32VGAES Slim USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to VGA adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to VGA Adapter - Slim Design - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32VGAES) - external video adapter - T5-302 - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Graphics Engine MCT Trigger 5 T5-302
Max Resolution 1920 x 1200
Interfaces VGA
Dimensions (WxDxH) 2.5 cm x 6.2 cm x 1.2 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Slim USB...
£46.88
