StarTech.com Slimline SATA to SATA Adapter with SP4 Power - S...
StarTech.com Slimline SATA to SATA Adapter with SP4 Power - Screw Mount
£14.04
Delivery:
Product codes
This cost-saving Slimline SATA to SATA adapter lets you connect a Slimline SATA optical drive to a standard SATA motherboard connection. The adapter features a Slimline SATA connector on one side and a standard SATA data connector on the other; power is drawn through a power supply floppy drive (SP4) connector, combining both data and power into the optical drive Slimline SATA connection. The adapter features a PCB-mounted design that can be securely fastened to the optical drive, eliminating loose connections.
Product Description StarTech.com Female Slimline SATA to SATA Adapter with SP4 Power - SATA adapter
Type SATA adapter
Connectors 13 pin Slimline Serial ATA - female
Connectors (Second End) 7 pin Serial ATA - male , 4 PIN internal power - male
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Slimline...
£14.04
