StarTech.com Solid Wire Cat 6 Modular Plug
£15.34
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to easily terminate your Cat 6 cable to the exact length required
  • Designed to fit all Cat 6 Patch Cables
Product codes
This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length equired.
StarTech.com Cat 6 RJ45 Modular Plug for Solid Wire - network connector - clear
Network connector - CAT 6
Packaged Quantity
50 (specifications are for single item)
Connector
RJ-45 - male
Clear
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Solid Wir...
£15.34
